I've ran these drives for years without issue. I moved my Z axis encoder and forgot to reverse the rotation. When I powered up, it overtraveled in the opposite direction, hit a physical stop, and the drive faulted out. I fixed my encoder issue and powered back on, but now my red and green lights are flashing. If I leave the main power disconnected, I get a nice green light, but if the power is connected I will get the red and green flashing lights again.
I lost my programming stick, so I ordered another one that should be here early next week. Maybe I can reset something with it?
Of course, I have moved components around with another drive that is good, and verified that the encoder, motor, control, etc. are working properly. It is definitely an issue with the drive.
Is there possibly an internal fuse or something that needs to be reset?
DG16035
Running 108VDC
Thanks!
