How use the spindle control output UC300 for my VDF
Postby Josemi77 » Sat Aug 12, 2023 11:49 am
First of all thank you very much for sharing your knowledge.
I would like to change the CNC controller of my machine and I have thought about the UC300 card. The doubt arises from the spindle speed control. My current VDF seems to be controlled by a 0-5 V input (PWM ???). I have reviewed information on the web, in the forum, I have contacted vendors but so far they have not resolved my doubts. I am going to attach a photo of the control port of my current VDF. Let's see if you can help me and clarify my doubts. Thanks in advance!
Josemi77
Re: How use the spindle control output UC300 for my VDF
Postby Dazp1976 » Wed Aug 23, 2023 10:53 pm
You should get the user manual. Look for the wiring diagram showing connections for a manual potentiometer control (positive+, wiper, gnd-). And post the diagram image.
Dazp1976
Postby Delco » Thu Aug 24, 2023 1:50 am
UC300 uses the analogue output pins , it outputs a 0-10V pwm signal , most VFD can be set to a 0-5v or a 0-10v signal in the parameter settings
Delco
