AXBB-E no boot response
Postby survtech » Tue Jul 11, 2023 11:32 pm
My AXBB-E has worked flawlessly for the last fifty weeks but will no longer boot.
The 5 volt supply is fine but when powering up there is no visual response at all - no led action.
survtech
Re: AXBB-E no boot response
Postby ger21 » Wed Jul 12, 2023 11:11 am
What about the 24V supply?
Postby survtech » Thu Jul 13, 2023 12:35 am
24Volt is fine led active
Thanks Gerry
survtech
Postby cncdrive » Wed Jul 26, 2023 12:26 am
What do you mean "no longer boot"?
What are the LEDs state?
Did you try to reset it with the reset button as described in the users manual?
Postby survtech » Wed Jul 26, 2023 12:33 am
"No longer boot" means that the boot-loader is dead.
With boot-loader dead, there are no status lights on the 5-volt rail.
Yes, re-set was first approach.
5-volt side was dead, AXBB-E was replaced under warranty.
The 5-volt power supply arced to ground (earth), I suspect that caused a spike.
Thank you for your help with this.
Mike
survtech
Postby cncdrive » Sat Jul 29, 2023 6:47 pm
Well, I don't understand, so your problem was solved now?
I mean you wrote the AXBB-E was replaced in warranty, so I guess the issue was solved?
