UB1 Drive wiring check
PostPosted: Tue Dec 06, 2022 9:25 pm
by SMITYP116
Good evening everyone,
I'm looking to finally convert my machine from DSP to UCCNC. Hardware wise I'm using a ub1 Bob.
The stepper drives are as per the picture below:
Looking at the manual I just want to double check my understanding of how ro wire the drives I have are correct. My understanding is as per the coloured dots on the above and below images
Hopefully my understanding is correct?
Many thanks
Paul
Re: UB1 Drive wiring check
PostPosted: Tue Dec 06, 2022 10:04 pm
by dezsoe
Yes, it's good.
PostPosted: Tue Dec 06, 2022 10:12 pm
by SMITYP116
Many thanks my friend. Would you say this should be sheilded twisted pairs. My current wiring from the company that built the machine isn't. But that was on the dsp setup.
PostPosted: Wed Dec 07, 2022 2:00 am
by fsli
SMITYP116 wrote:Would you say this should be sheilded twisted pairs.
Twisted pair isn't necessary, but shielding could be beneficial. I used shielded aircraft wire with 22 gauge conductors. It's lighter and thinner than STP (that is, network cable).
Terminate the shield on one side only. I used solder sleeves with a 22 gauge pigtail.
https://www.aircraftspruce.com/catalog/ ... ckkey=6369
https://www.aircraftspruce.com/catalog/ ... kkey=14313
