There's a great response from PMDX here as I try to reconcile my massive ignorance with my desire to do rigid tapping:
http://www.pmdx.com/PMDX-Forums/index.php?topic=331.0Most of it has to do with signal compatibility with the PMDX BOB, but it's still useful information.
As for your encoder... Do the math. I had a 2048PPR encoder that came with my motor and was all excited to use it. Once I did the math after discussing with Bob at PMDX, I realized that at 5kRPM the encoder is pulsing at something like 170kHz. This is WAY too fast for the BOB to handle.
Is the bottleneck the optocouplers or the general input signal? I've no clue. Really, I'm just regurgitating along what I've read and the responses I've received as I've tried to educate myself. Think monkeys and keyboards and machine tools here.
Even with a 1kPPR encoder, it's about 83.3kHz. 5000RPM x 1000PPR = 5,000,000 pulses per minute, or 83,000 pulses per second. Can your BOB or whatever is receiving your signals handle that input speed? You may be in business, but you need to check the specification for max input speed on
all your hardware.
Ignore the fact that some servo amplifiers are processing 16 bit encoder signals in the MHz range. They are specifically designed for this, and I've seen/read - no direct experience - where they have 'pass-through' outputs to the motion controller for use in trajectory planning (sexy closed-loop to the software). These pass-through circuits can be set in the amplifier to a much lower pulse frequency that the controller can handle.
After much searching, I found that it was cheaper to purchase a new encoder with a 100PPR resolution and sell the old one than try to purchase a signal divider. If you're dying to buy a circuit divider, the bigger encoder companies have them - check with BEI, Dynapar, ect. and be prepared to vomit. Automation Direct has one, too - but it still expensive. I'm not clever enough to design & solder one up myself, and I didn't want to go to the effort of learning how only to find that what I cobbled up caused signal issues that I'm not competent to sort out.
I went with a Photocraft (Tri-Tronics) because it was inexpensive(ish), but not plastic garbage. I was able to select all the features I wanted (signal type, voltage, shaft diameter, mounting, PPR, etc.) on their web site and it was in my itchy hands 4 days later. 1/3 the price of a BEI or Dynapar, and no searching FleaBay for days and days looking for just the right thing with 4 different tech manuals open trying to decode the manufacturer's model numbers. That was a miserable way to try to save a few bucks...
If you punt and go the used route, pay attention to the signal types, circuit output types, and RPM limitations on some of the older models. You may find the perfect encoder, only to discover that it has a really nice shaft seal on it - except you can't run it over 3kRPM because that IP66 seal will get smoked.
Good luck.
-S
