AXBB Wiring to driver question
Postby Fabmonster » Sun Sep 22, 2019 1:04 am
Here is my driver please explain to me how to wire this thing. I’ve been trying to figure it out for a week with no success. I tried wiring cp- cow- to ground 5vo on axbb then cp+ to pin 9 port 1 and cw+ to pin 10 port 1 and no movement. HELP -PLEASE
Fabmonster
Re: AXBB Wiring to driver question
Postby Robertspark » Sun Sep 22, 2019 6:32 am
CP is your step signal
CW is your direction signal
section 9.2 of the manual shows 2 wiring options
https://www.google.com/url?sa=t&source= ... M24AixmJtf
if it were me:
I would wire the 5V0 to CP- and CW-
I would then wire one of the non isolated outputs OF to 017 to CP+ and a separate (different) non isolated output to CW+
but as section 9.2 shows you you could wire up CP+ and CW+ to 5V+ and then you would wire up CP- and CW- to separate non isolated outputs OP9-17
either will work
it is clearly shown in this diag
https://www.cncdrive.com/img/AXBB-E_5.png
Postby cncdrive » Sun Sep 22, 2019 7:17 am
If the CP+ is wired to a non-isolated output and CP- is wired to 5V0
Or
if the CP+ is wired to the +5V and the CP- is wired to a non-isolated output
then it should run to one direction even if the CW+ and CW- is left unconnected.
