commander se
commander se
Postby windows20 » Thu Mar 28, 2019 9:54 am
commander se
not got a clue what to do here.can some one help me connect to the axbb-e board please.
windows20
Re: commander se
Postby windows20 » Thu Mar 28, 2019 5:45 pm
ok got 1 wire from 10 on vfd and 1 wire from 7 when i connect them together they turn on spindle.just cant work out where to put them on the bob now.
windows20
Re: commander se
Postby dezsoe » Thu Mar 28, 2019 5:55 pm
AXBB has common ground (0V), so it will not work this way. You should use a 24V relay to short your wires. See the AXBB manual how to connect a relay to O2..O8. (O1 is reserved for charge pump, but it works the same way.)
Re: commander se
Postby windows20 » Thu Mar 28, 2019 6:02 pm
is that my only option to get a relay.
windows20
Re: commander se
Postby dezsoe » Thu Mar 28, 2019 7:07 pm
You can also use an optocoupler+resistor instead of the relay.
Re: commander se
Postby windows20 » Wed Apr 03, 2019 5:21 pm
Do all vfds have to use a relay to connect to this board then.
windows20
Re: commander se
Postby ger21 » Wed Apr 03, 2019 5:51 pm
It's common to use a relay to start/stop the spindle, regardless of what board is used.
Re: commander se
Postby windows20 » Wed Apr 03, 2019 6:22 pm
Can you recommend 1 then please.
windows20
Re: commander se
Postby ger21 » Wed Apr 03, 2019 6:34 pm
Re: commander se
Postby windows20 » Wed Apr 03, 2019 7:15 pm
Does it matter what voltage
windows20
