Pre purchase questions..
First, please keep in mind I'm a dope and will be confused, lol.
I recently added a laser kit to my CNC router and have had a few problems. My current router setup is Win7 (64), Mach3, Ethernet Smoothstepper, Gecko540. To add the laser I purchased a DAC board to convert C-axis to PWM for the laser driver. No matter what we do (we, being myself and a bunch of other ppl) cant get it to NOT lose position (intensity of laser gets out of wack). I have another DAC board on its way to rule out a faulty board but I am not 100% that will solve it. What I do think will solve it is software that has fast enough PWM output. Mach3 is out, Mach4 is an option and I hope also UCCNC Software (but I will need 5LPT-UC300 Motherboard also). Spoke with a forum member and sounds like UNCNC might be the answer.
Ok, question time.. (round one) I have the demo installed so If you want me to look at a page I can follow along.
I would like to try and future proof my setup. What would be better? I currently run Mach3 with Ger21's 2010 Screenset and I am quite comfortable with it so I will be getting his 2017 for UCCNC. I am guessing (A).
A. Two profiles, Laser Profile & Router Profile so its all separate and not confusing under one screenset.
B. One profile that has both laser and router setup
I do not have a PWM spindle yet but would like one soon. I took a quick glance through the manual and I'm a little confused. I already have the LPT-Header Cable to connect my G540.
1. Will I use another 26pin BOB (have one on hand already) for the laser or is Laser and Spindle PWM output on [Port A] 16pin BOB?
Maybe an explanation as to how I should wire would be easiest, lol.
