Laser/spindle combo
Re: Laser/spindle combo
Postby cncdrive » Sun Jun 03, 2018 4:47 pm
The polarity for the laser on is then probably the opposite for the laser as for the spindle on. (active low setting)
Postby sngatlanta » Mon Jun 04, 2018 6:56 pm
cncdrive wrote:The polarity for the laser on is then probably the opposite for the laser as for the spindle on. (active low setting)
I switched the active Low setting for the I/O and the Spindle Active Low on and off, to all compinations and still the Laser is on when the Spindle ( M3 ) command is off. When given the m3 command to turn on the Spindle I regain control of the lasers m10 and m11 comands.
Any help is appreciated.
sngatlanta
Postby dezsoe » Mon Jun 04, 2018 7:10 pm
Could you upload your profile? There must be something misconfigured.
BTW, did the G52 work for you?
