Update firmware on every UCCNC start, then lost connection
Postby shad » Wed Feb 14, 2018 3:22 pm
Hello Balazs!
Please tell me what can happens with controller?
On every UCCNC start the program initiate firmware update.
Update done, but then UCCNC lost connection to the controller.
We try to use 1.2047 version and 1.2102 version no sense.
This is a short video about issue https://yadi.sk/i/YDPUWA9p3SPri7
Thank you!
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
http://neuroncnc.com/
shad
Re: Update firmware on every UCCNC start, then lost connecti
Postby cncdrive » Wed Feb 14, 2018 4:51 pm
Is it with direct connection to the PC or via router?
If it is via router then can you try it with direct connection?
Also try to disable the DHCP in the controller.
And you could also try to reset the controller.
Postby shad » Thu Feb 15, 2018 5:30 am
Thank you!
I will try and report.
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
