New UC300ETH Breakout Board
Re: New UC300ETH Breakout Board
Postby dezsoe » Thu Nov 16, 2017 1:11 pm
Thank you, Gerry! Can you turn it on in reset mode too? (The job would be that.)
Postby ger21 » Thu Nov 16, 2017 1:24 pm
I'll try to test this weekend.
Postby dezsoe » Thu Nov 16, 2017 3:00 pm
OK, thanks in advance!
Postby Wildcat487 » Sun Jan 08, 2023 8:48 pm
ger21 wrote:This jumper determines whether UCCNC sees it as a 5LPT board or a UB1 board. Different screens are loaded based on which board is detected.
I'm still confused after reading both the UB1 and UD1 manual. Do solder this if I am using both boards together? E.G. solder this pin on the UB1 and UD1.
Wildcat487
Postby dezsoe » Mon Jan 09, 2023 8:59 am
UB1 manual wrote:The UB1 was developed by following UC300ETH_5LPT Motherboard pin out. Choosing the 5LPT jumper will get 100% pin to pin compatible, except analog channel output 2 which will not function properly. Choosing the UB1 jumper the user will get 100% pin to pin compatible and the analog output will function properly. The reason for this is that the UB1 isolated analog circuit uses a frequency of 1 kHz while the 5LPT board uses a frequency of 48 kHz.
The jumper has nothing to do with UD1. The main function of the jumper is to make Analog output 2 to work properly.
