ger21 wrote:Then use 24V as the manual specifies, and the board was designed for.
cncdrive wrote:The outputs can work with 12Volts, they are simply N-channel mosfets, so they can work with any voltage up to about 50Volts.
The inputs optocouplers series resistors are sized the same as the AXBB-E input resistors and they work down to 5Volts without problems. (tested)
The only thing I do not know is if the internal 5V voltage regulator which makes 5V from the 24V has any issues with 12V instead of 24V, however the worst case scenario is still that it will not output voltage and it might give audible sound.
So, the worst case scenario still will not damage anything on your board, so there is basically no risk.
If there were risk for damage then ofcourse I would tell what you said...
