UC400ETH with Mach3 Turn profile
Postby CyclopsNC » Thu Oct 18, 2018 3:08 am
For some reason UC400ETH doesnt work with the Mach3 default Turn profile although it does work with the Mill profile. I guess its nothing to do with the profiles but just changing the settings in the "Ports and Pins" dialog should get it to work.
Unless I'm wrong, Is this by design or I just have to run through the settings and UC400ETH should work anyway with the turn profile.
I have checked the settings in the Ports and Pins for the turn profile and don't seem to be doing much wrong over there.
CyclopsNC
Re: UC400ETH with Mach3 Turn profile
Postby cncdrive » Thu Oct 18, 2018 4:36 am
It should work the same with the Mill and the Turn profiles.
Postby asuratman » Fri Dec 21, 2018 3:10 am
How can we use mach3 turn profile on uccnc ? So, we can use this to run lathe. Let me know.
asuratman
Postby ger21 » Fri Dec 21, 2018 11:44 am
CyclopsNC wrote:For some reason UC400ETH doesnt work with the Mach3 default Turn profile although it does work with the Mill profile.
Try creating a new profile from scratch. Mach3 .xml files often become corrupt and no longer work properly.
Postby Robertspark » Fri Dec 21, 2018 12:08 pm
It is not possible to use a Mach3 PROFILE on uccnc.
Cncdrive do have mach3 plugins for all of their motion controllers so you can run mach3 with uc100, uc300 and uc400eth motion controllers
Mach3 and uccnc are totally different
