Macro_capability_detailed.htm - suggested corrections
This section is for Users that want to create and share Documentation about UCCNC.
Re: Macro_capability_detailed.htm - suggested corrections
Postby ger21 » Sat Oct 22, 2016 11:06 am
I know it's more work, but I'd prefer 3 different manuals, or at least 3 different sections.
Very, very few users will ever write plugins, so why make them have to parse through a document where a large percentage of the items don't pertain to them?
Just my thoughts, you don't need to agree. :) (I'm very grateful for what you've done)
Personally, I'd like a "quick reference", with just a list as you've posted in those previous emails. I'm going to copy those two emails and print them out.
Postby beefy » Sat Oct 22, 2016 8:22 pm
If you end up doing the 3 different manuals you could just have 3 letters next to each command (S M P), example if the command can be used in a screenset and a macro but not in a plugin S M P
Any good ??
Or the P could be grayed out or striked through.
Keith
beefy
Postby Robertspark » Sat Oct 22, 2016 8:45 pm
Comments below noted, keep them coming (off outside, get a chance to cut a bit of plate this evening).
found another macro function in M200 macro (listed here so I can find it later for the manual, may be of use to someone in the interim)
int originalmodalmode = exec.actualmodal; // remember the modal mode
exec.Code("G" + originalmodalmode); // Set system back to the original distance mode
Rob
UCCNC v1.2110 Macro Manual
Postby Robertspark » Sat Oct 22, 2016 9:44 pm
Is it not g90/g91?
Rob
Postby Robertspark » Fri Oct 28, 2016 11:13 am
exec.actualmodal function
  string OMM = originalmodalmode.ToString();
  MessageBox.Show(OMM);
//   exec.actualmodal
//   returns [as int]>
//   "0" = G0 - Linear interpolation with maximum feedrate
//   "1" = G1 - Linear interpolation with set feedrate
//   "2" = G2 - CW arc interpolation with set feedrate
//   "3" = G3 - CCW arc interpolation with set feedrate
exec.actualdistmode function
   int originaldistancemode = exec.actualdistmode;
   string ODM = originaldistancemode.ToString();
   MessageBox.Show(ODM);
//   exec.actualdistmode
//   "90" = g90 - absolute distance mode
//   "91" = g91 - relative distance mode
both found in M204.txt macro
Rob
Postby Robertspark » Fri Oct 28, 2016 11:16 am
exec.DospinCW();
exec.DospinCCW();
exec.Stopspin();
exec.Miston();
exec.Floodon();
exec.Stopcoolant();
found in macros M3, M4, M5, M7, M8 & M9.txt respectively.
Rob
Postby ger21 » Mon Oct 31, 2016 11:34 pm
To press a button from a macro:
exec.Callbutton(int ButtonNumber)
To Change Tab layers from a macro:
AS3.selectlayer(int LayerNumber)
Took me a while to figure out the second one. :)
Postby Robertspark » Tue Nov 01, 2016 2:38 pm
Thanks Gerry, I'll update them, not started on a plugin section, need to issue the updates as there are a couple of extra fields, buttons and LEDs in v027
Rob
Postby ger21 » Wed Nov 23, 2016 2:31 am
AS3.Getfielddouble(****)
Also, this thread should be moved. Took me 10 minutes to find it.
Postby Robertspark » Wed Nov 23, 2016 9:06 am
Could someone please move this to the documentation section?
[May be a good idea to do a bit of housekeeping as there is stuff like the ISOBOB that could be moved to hardware, etc etc]
Rob
Return to User Documentation
