No plasma jet when THC is on
Postby P0ppy » Thu Jan 27, 2022 6:54 pm
God bless You,
When I have set up Mach3 to use Proma THC 150, plasma torch stopped cutting material even if I turn it on manually by clicking F5. Previously torch had worked.
What should I change in Mach3 configuration to troubleshooting?
Best regards,
P0ppy
P0ppy
Re: No plasma jet when THC is on
Postby P0ppy » Fri Jan 28, 2022 1:48 pm
P.S.: I use AXBB-E to control plasma cutter.
P0ppy
End of thread
Postby P0ppy » Mon Feb 07, 2022 1:11 pm
God bless You,
I have found solution. Relay for torch hasn't been working, so it gets replaced with another one. Torch is working now.
Sincerely,
P0ppy
P0ppy
Return to CNC Plasma
