wiring axbb-e with Proma THC 150
Postby cncrail » Mon Jan 18, 2021 3:20 pm
Hello everyone . I just bought AXBB-E, I would like to have the wiring diagram between this and the THC 150 from Proma which is in my possession.. Grazie
Antonino Bortiglio
cncrail
Re: wiring axbb-e with Proma THC 150
Postby cncrail » Mon Jan 18, 2021 8:20 pm
software : UCCNC CNCDRIVE control software for USB and ETH controls
Valid alternative to Mach3, the software works only together with the usb or ethernet controls UC100, UC300, UC300ETH, UC400ETH, AXBB-E, natively supports the THC of Proma, imports the mach3 configuration files (profiles) i bought for this reason!!!
cncrail
Postby cncdrive » Mon Jan 18, 2021 10:06 pm
The proma THC150 outputs 3 signals, ArcOK, THCup and THCdown.
You can connect the signals to any inputs of the AXBB-E, then you just have to configure these functions to the inputs as per your connections.
Postby cncrail » Tue Jan 19, 2021 7:33 am
hello thanks for the answer can i configure with mach3?
cncrail
Postby cncdrive » Tue Jan 19, 2021 6:13 pm
Yes, it works with mach3 too.
Postby cncrail » Wed Jan 20, 2021 9:54 am
ma posso portare la stessa configurazione in UCCNC dal mach3
cncrail
Return to CNC Plasma
