by limited660 » Wed Jun 24, 2020 1:31 am
Well found it myself. If you search the post for "if (jetMode) {" you can comment out "zOutput.disable();" and enable Z axis moves in the post.
If you prefer to just use a post, I've attached one where I have added a property called "Use Z axis - Jet Mode" where you can turn this off/on. You will need to change extension of file from txt to cps.
- Attachments
- uccnc.txt
- (58.59 KiB) Downloaded 514 times
