UCCNC With Capasitive Thc
Postby SHP » Thu Mar 05, 2020 1:16 pm
Is the Uccnc compatible with capasitive thc Cap04 from Agelkom? Does the software need a plasma screenset when working with plasma, or just leave it as standart?
SHP
Re: UCCNC With Capasitive Thc
Postby jcoldon » Fri Mar 06, 2020 3:15 am
uccnc plasma screen set . plasma supports thc up down inputs.. thc control in dun in the controller in real time
i been running an Axbb control a year now works well thc works good also
jcoldon
Postby SHP » Fri Mar 06, 2020 3:31 pm
thanks jcoldon. is the m3 from mach3, is configurable in uccnc? dont have to modify if i place it, into uccnc macro?
SHP
Postby jcoldon » Wed Mar 11, 2020 3:57 pm
in your post processor you would use the M31 probe macro in place of the g31 . then in uccnc under files uccnc/profiles and macro you load the plasma M31 macro in there
or you can use the G31 in your post processor
I have attached a post processor for sheet cam you can try it uses the G31 probe .set your offset settings .for the probe switch or in your case cap unit .
and can turn off and on thc. in code with sheet cam .
it also does safe probe mode. using M213 M214 . what that does is turn on the ability to use the probe input wile cutting for anti coulision .
if you don't need that. look down in the M2 and M5 you see the codes M213 and M214 it goes on after m3 and off after m5 .
M3 spindle on torch fire and M5 spinde off torch off ..
hope this helps
plasmapost.txt
plasma post processor
(9.58 KiB) Downloaded 161 times
jcoldon
Postby SHP » Thu Mar 12, 2020 7:02 am
Thanks a lot, Jcoldon for the solution.
SHP
Return to CNC Plasma
Users browsing this forum: Google [Bot] and 2 guests
