Gcode not Proceeding to G01
Postby Spoolnms » Wed Dec 04, 2019 2:21 am
I am still trying to dial my machine in. Now that I have a floating Z I am trying to make the THC operational. I am using the UCCNC post for Sheetcam. It was working for a bit as I was trying to dial it in, but now when running the code, it stalls between M03 and G01 lines. The plasma turns on, but just sits there for an extended period of time. What could cause this? This actually happened with a few other Mach3 with THC posts before, I just figured that they were not compatible with UCCNC, now I can't seem to get it to run the original code. Any thoughts?
Spoolnms
Re: Gcode not Proceeding to G01
Postby cncdrive » Wed Dec 04, 2019 3:31 am
The Arc OK input signal is not turning on makes the controller to wait after an M3 goes on and the THC is switched on.
The issue has nothing to do with the post processor you using, but your THC controller.
Return to CNC Plasma
