Changing IP address for Neuron Lite
Postby andrewwong2000 » Fri Nov 15, 2019 2:37 am
Hoping that this doesn't become the only place I can get help on running a Neuron CNC Lite...
How does one change the IP address of the unit.. I've seen conflicting screenshots of NeuronFlasher utility,
that show a field to set the IP address when you flash the unit, and the version of NeuronFlasher that is
currently sitting in the Dropbox install folder that doesn't seem to let you set the ip address.
I can connect to the unit at the default ip of 10.10.10.100, and otherwise have confirmed it works in UCCNC (albeit by using 2 separate
networks!)
andrewwong2000
Re: Changing IP address for Neuron Lite
Postby andrewwong2000 » Fri Nov 15, 2019 7:17 am
In case anyone else is interested.
Andrew advised that there are 2 IP addresses in the Neuron Lite. One is in the bootloader that cannot be changed, and one is in the firmware that is hard coded. This is tricky if you are connecting it to a network, and a hassle to change via firmware update!
I asked if we can get an option to boot using DHCP, avoiding the need to hard code IP addresses.
andrewwong2000
Return to CNC Plasma
