Help wiring THC
Re: Help wiring THC
Postby Spoolnms » Sat Nov 16, 2019 11:37 pm
Ok, finally got back around to messing with it again. Got a floating z plate, and got it configured in UCCNC correctly. For the post processor, I am using Mach 3 with thc and scriber with backlash comp. When I go to start the job, itll lower until it trips the floating z switch and instantly start (torch still touching the work piece). Where do I tell it to raise up xxx amount?
Spoolnms
Re: Help wiring THC
Postby Vmax549 » Sun Nov 17, 2019 2:08 pm
You set the pull up value in the sheetcam post.
(;-) TP
Vmax549
Re: Help wiring THC
Postby Spoolnms » Sun Nov 17, 2019 2:41 pm
I don't see the pull up value. Is it the switch offset?
Spoolnms
Re: Help wiring THC
Postby Spoolnms » Sun Nov 17, 2019 3:25 pm
Ok I figured it out, thank you. Now my rounded corners are lines lol.
Spoolnms
Re: Help wiring THC
Postby Spoolnms » Mon Nov 18, 2019 10:07 pm
Any insight on wha to correct in the post? Im using the mach3 thc with scriber and backlash adjustments. Wasnt doing it with the mach3 post
Spoolnms
Re: Help wiring THC
Postby cncdrive » Mon Nov 18, 2019 10:24 pm
It is path deviation tolerance setting problem in the UCCNC. This was answered on the forum several times, please search the forum or read the users manual, the constant velocity parameters description.
Re: Help wiring THC
Postby Spoolnms » Mon Nov 18, 2019 10:59 pm
But this problem didnt exist with mach 3 or mach3 thc post processor. Only the current post.
Spoolnms
Re: Help wiring THC
Postby cncdrive » Mon Nov 18, 2019 11:03 pm
It has nothing to do with the post processor. or maybe it does, but without seeing your g-code file we can just guess.
Re: Help wiring THC
Postby Spoolnms » Mon Nov 18, 2019 11:36 pm
Definatly the post processor as it dosnt do it on the others. Ill post the gcode up when i get back out to the garage
Spoolnms
Re: Help wiring THC
Postby Vmax549 » Tue Nov 19, 2019 12:25 am
Why don't you use teh UCCNC plasma with scriber post ??
Just a thought, (;-) TP
Vmax549
Return to CNC Plasma
