Jerky movement on X/A axis
Re: Jerky movement on X/A axis
Postby kawarider » Fri Nov 08, 2019 4:33 pm
It didn t let go. As soon as I got home, check it. It is definitely the kerf offset and the small arcs that is introducered bij sheetcam. Line is almost straight with 10 degree angle. With kerfwith very jerky, no offset, very smoorh. What is the best way to solve this?
Cv on
Stop angle 89 degr
Look ah 300 lines
Lin error 10
Lin add 1
Lin uni 2
Corner err 1
Arc radius tol 10
Machine cuts at 3800 mm/min
Acc 3000 mm/s2
Uccnc300eth
Neuron lite
Powermax45
So far everything I found on the internet didn t help. Anyone?
Thanks!
kawarider
Return to CNC Plasma
