x-y motion stops for no reason - plasma
Hi , I have random x-y motion stops on the last portion of lead out.I have to press the stop and then start button to resume the job.When it stops in the x-y motion , the torch fire LED is still lit( plasma torch is off ) .When the stop button is pressed again , LED goes off ( torch relay clicks off ).
My signal from the THC arc on , is from a promo THC.I run the file with and without sheetcam path rules and it seems to be the same problem.
Any help will be much appreciated.
