M5 delay UCCNC+NeuronLite
Postby tõnisson » Wed Feb 07, 2018 8:06 am
When XY movement stops, there is a 1+ sec delay before torch shuts off.
What could cause a delay that long?
Kristian
tõnisson
Re: M5 delay UCCNC+NeuronLite
Postby cncdrive » Wed Feb 07, 2018 1:42 pm
What is controlling the torch? The UCCNC via a motion controller pin controlled by a M3/M5 or via the Neuron or a combination of both?
If it is controlled by the UCCNC is what I can talk about is that if there is no M5 delay setup then there should be no more than a few tens of milliseconds delay.
If it's controlled by the Neuron then there may be a setting in the plugin which causing the delay, but please ask Andrew (Shad) about this.
Postby shad » Wed Feb 07, 2018 5:50 pm
Hello tonisson!
Please tell me, what plasma cutter do you use?
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
http://neuroncnc.com/
shad
Postby tõnisson » Wed Feb 07, 2018 9:32 pm
Powermax 85, but Olavi just said, that he sent email directly to you with the problem.
Kristian.
tõnisson
Postby shad » Thu Feb 08, 2018 5:48 am
Yes Kristian, we try to check it today.
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
Return to CNC Plasma
