Macroloop - Log Gcode File Load + Log File Run Time
Please find attached two macroloops (you only need one loaded).
M1002.txt is the basic macroloop which will just log when a file is run (the time the file is started to run)
M1003.txt is a macroloop that will log when a gcode file is loaded and when the file is run.
Either macro could be altered to include when a gcode file was ended (let me know if you require this).
The default file location for the text file to be saved is the "C:\UCCNC\Example_codes\" folder although you can change this as you require....
M1002 and M1003 save to different files (so you could load both macro loops if you require or do so by error...)
You could also change the file extension to "csv" from "txt" should you wish to save the file to comma seperated value and open in MS Excel / orther spreadsheet application....
Save the files to the relevant profiles folder which matches your profile that you are running.
Load the macroloop files via the Configuration screen >> General Settings screen >> Macroloops button
