Plugin - On-Screen Keyboard / Calculator
Postby dezsoe » Tue Jul 18, 2017 9:17 pm
This plugin helps entering numbers into input fields. Enable the plugin (Call startup not needed), then click into any input field: you get a calculator-style on-screen keyboard, and it is really a calculator. You can do the following:
    * type any numbers
    * use g-code functions (abs[], etc.)
    * use actual #nnn variables
    * use special variables as x, y, z, etc.
    * write/read/clear memory
Check attached pictures, download, use!
(The missing two buttons will have their functions in version 2.0 some weeks later.)
Requirement: UCCNC version 1.2029 or higher.
Download link 1
Download link 2
Re: Plugin - On-Screen Keyboard / Calculator
Postby Robertspark » Tue Jul 18, 2017 9:50 pm
nice plugin, thanks :D
Postby gabi68 » Sun Sep 03, 2017 3:20 pm
How is this plugin supposed to wok? I install it and it does the calculation required, but the machine does not move on the new location. What I am doing wrong?
Gabi
gabi68
Postby dezsoe » Mon Sep 04, 2017 9:44 am
The machine won't move to the new position if you enter a coordinate, so if you enter it with the help of this plugin, it still won't move. This plugin is for helping the input with on-screen keys (using only mouse or touchscreen) and, if needed, calculation and/or memory etc.
If you need some fields to set a movement, you need to program it. Put fields on the screen and write a macro which reads these fields and moves to that position.
Postby dezsoe » Tue Jul 17, 2018 9:02 am
The new version of OSK is now available on the original download links in the first post. Also included in test version 1.2106.
- now supports MDI input with history and 3 keyboard layout (QWERTY, QWERTZ, AZERTY) for MDI supported characters. Also, OSK can be switched to 75% opacity
- can be called from macros/plugins
Sample/test macro:
object Returnvalue;
double? result;
string mystring;
// test0 - check if plugin is enabled
Returnvalue = exec.Informplugin("UCCNC_OSK.dll", (object)null);
bool isrunning = false;
if (Returnvalue is bool) isrunning = (bool)Returnvalue;
if (!isrunning)
  exec.AddStatusmessage("On-Screen Keyboard plugin not enabled!");
  return;
// test1 - numeric input with default value
Returnvalue = exec.Informplugin("UCCNC_OSK.dll", (object)"calc:1.23");
result = null;
if (Returnvalue is double?)
  result = (double?)Returnvalue;
  if (result != null)
    exec.AddStatusmessage("Result: " + result.ToString());
  else
    exec.AddStatusmessage("Result: none");
else
    exec.AddStatusmessage("Result: not double?");
// test2 - numeric input
Returnvalue = exec.Informplugin("UCCNC_OSK.dll", (object)"calc");
result = null;
  if (result != null)
  else
else
// test3 - string input with default value
Returnvalue = exec.Informplugin("UCCNC_OSK.dll", (object)"text:blabla");
mystring = "";
if (Returnvalue is string)
  mystring = (string)Returnvalue;
  exec.AddStatusmessage("Result: '" + mystring + "'");
else
    exec.AddStatusmessage("Result: not string");
// test4 - string input
Returnvalue = exec.Informplugin("UCCNC_OSK.dll", (object)"text");
mystring = "";
else
Return to UCCNC TOOL BOX
