Pin mapping plugin
Pin mapping plugin
Postby dezsoe » Tue Apr 03, 2018 8:58 am
In the 1.2104 test version already included, but if you want to use it in older versions, you can download the Pin mapping (Pinout.dll) plugin. With this plugin you can test and verify the current or a loaded profile. It works with all (32 and 64 bit, .Net2 and .Net4) versions. Download from here or here. Copy the Pinout.dll and Pinout.ini to the UCCNC\Plugins folder, the docs to UCCNC\Documentation foler. (The docs are not needed for the plugin to work, but it may be good to have them by hand.)
Download 1
Download 2
Re: Pin mapping plugin
Postby A_Camera » Tue Apr 03, 2018 1:33 pm
Excellent work and is very useful! Thank you very much.
Return to UCCNC TOOL BOX
