Drill holes from a Points file.
Postby Vmax549 » Fri Mar 09, 2018 5:17 pm
IF you ever get the need, I have a new Macro function that allows you
to drill hole patterns from a points file. The macro can CALL the pointfile
and feed the drill cycle the points from the file. You also have a choice for
drill cycles G81/G73. You program the basics of the drill cycle from the
macro.
P = Cycle (81/73)
E = Zdepth
H = retract height
Q = peck on teh G73 cycle
( DrillPoints.txt ) Located in C:\UCCNC\Points
G80 G90 G49
G0 X0 Y0
G1 X1 Y1
M3 S2375 M8
G98
M400 P73 E-1.532 H.123 Q.050 F35 (DrillPoints.txt)
G0 X0 Y0
M5 M9
M30
********** Points file layout CSV Comma seperated ( Xvalue,Yvalue) no
spaces
and no empty lines allowed
1,1
1.250,1
1.500,1
etc
etc
Place the macro in your macro folder and place the points file in C:\uccnc\points.
Then you can call the macro from the MDI or from Gcode.
M400.txt
(3.09 KiB) Downloaded 67 times
DrillPoints.txt
(112 Bytes) Downloaded 70 times
Vmax549
Return to UCCNC TOOL BOX
