Button (Macro) - Call *.exe
Postby Robertspark » Thu Aug 03, 2017 1:40 pm
Similar principle to the call (open) usermanual PDF.
.... this one just starts a program of your choosing from a UCCNC screenset button press, in this case Sheetcam (obviously won't work for you directly unless you have sheetcam ..... hence change it to the program of your choosing [vectric, autocad, stepper motor tuning software [leadshine protuner from the diagnostics screen] etc...
System.Diagnostics.Process Sheetcam = new System.Diagnostics.Process();
Sheetcam.StartInfo.FileName = @"C:\Program Files (x86)\SheetCam TNG Development\SheetCam TNG Development.exe";
Sheetcam.Start();
M20001.txt
(202 Bytes) Downloaded 94 times
Rob
UC400eth, UC300eth, UCCNC v1.2105, Neuron Lite
UCCNC v1.2105 Macro Manual
Re: Button (Macro) - Call *.exe
Postby dezsoe » Thu Aug 03, 2017 2:05 pm
The same technique to use your favorite text editor to edit g-code. Edit screen and change "Edit file" buttonnumber from 126 to 20126. In M20126.txt change the path to your favorite text editor.
// 126 -> 20126 -> external code editor
string sFileName = exec.mainform.filenametoload;
if ((sFileName == "") || (sFileName == Application.StartupPath + "\\Contents\\Empty.txt"))
  AS3.Additemtolistbeginning("No file loaded!", 2);
  return;
System.Diagnostics.Process proc;
proc = System.Diagnostics.Process.Start(@"C:\Program Files (x86)\PSPad editor\PSPad.exe", sFileName);
proc.WaitForExit();
exec.mainform.loadfile();
M20126.txt
(446 Bytes) Downloaded 99 times
Return to UCCNC TOOL BOX
