Macro - M56 (as MSG) - write message to status
Postby dezsoe » Fri Feb 02, 2018 4:46 pm
Here is a macro for displaying messages to status window. It shows the contents of the comment between ( and ). You can print variables with the format #nnn or #Fnnn, where nnn is the number of the variable, F stands for formatted to 4 decimals. See screenshot below:
And a test g-code to start with:
#100 = 1.23
#101 = 3.45
M56 (Hello operator 1!)
(Hello operator 2!)M56
M56(Hello operator 3!)G0
M56(Var 100 = #100)
M56(Var 100 formatted = #F100, var 101 = #101)
M30
Edit: You need min. 1.2102 for this macro to work!
M56.txt
The M56.txt macro
(1.51 KiB) Downloaded 273 times
Re: Macro - M56 (as MSG) - write message to status
Postby BKG » Tue Jun 18, 2019 8:14 pm
Hello, the newest version is 12049 i can not gett it working in that version ??
BKG
Postby ger21 » Tue Jun 18, 2019 8:31 pm
You need the development release (#3)
http://www.cncdrive.com/UCCNC.html
Postby beefy » Fri Jun 21, 2019 9:18 pm
Thanks Dezsoe.
Keith.
beefy
Return to UCCNC TOOL BOX
