PortPin Select
PortPin Select
Postby Dan911 » Mon Nov 20, 2017 1:23 am
This plugin will activate a Pin with a toggle button easily created in UCCNC, this will also work with Estop engaged where a macro alone won't work. I originally written this by a request in a thread and uploaded for others similar to his needs. There are other good solutions in thread to accomplish this but thought this my be appealing to the less savvy macro users.
Thread can be found here>>>>>>>>>>> viewtopic.php?f=11&t=855
Instructions are simple and below:
1. Create a toggle button in screen edit and give it a button #.
2. Put PortPin plugin in plugin folder.
3. Go to configure for plugin and check startup and enable.
4. Fill in toggle # of toggle you created and port & pin to manual control and press save.
The attachment PortPin.JPG is no longer available
Hope someone may find use and can download from link below.
