Huanyang Plugin
Hello All,
This plugin discussion and development started on the Zone so that's where the plugin is uploaded, there's been a few post here about it so I'm starting a thread and hopefully any farther discussions or problems can be discussed here to help consolidate all info.
Anyone making the switch from Mach3 and parallel port connection to UCCNC with a UC100 and a Huanyang VFD like myself is going find this plugin most useful, but it will also work with any UCCNC controller with UCCNC software. It was originally written for the typical Chinese Spindle you find on Ebay but could be used for any motor/spindle being powered by the Huanyang VFD if set up properly in the plugin configuration window. The pulley system can be used also as long its set up in UCCNC with pulleys checkbox checked, different pulley ratios can be called like you normally would in UCCNC with
M215 PX. Calling pulley with this method you will get a window with new max rpm calculated with pulley ratio and max RPM in motor set up. This max rpm should be used for max rpm in UCCNC pulley set up.
Hope someone finds this plugin as useful as I do, and link is below, make sure you download latest version 1.0007
http://www.cnczone.com/forums/uccnc-con ... cro-6.html
