Huanyang Plugin
Re: Huanyang Plugin
Postby andrewbishop66 » Tue Nov 07, 2017 9:32 pm
So quick Kitchen table test and have coms with vfd with new rs485 to usb so that would seem to be problem now just need to set up on the mill
Thanks Dan for all your help and for taking the time to make the thing in the first place
andrewbishop66
Re: Huanyang Plugin
Postby cncdrive » Tue Nov 07, 2017 9:36 pm
Andrew,
So, the issue was with the USB - RS485 adapter?
I think others would probably appritiate if you can post some info on which adapter is what is not working properly and which is the one which you had success with?
I mean other users could avoid buying the non working adapter if you will post the informations.
Re: Huanyang Plugin
Postby andrewbishop66 » Tue Nov 07, 2017 10:54 pm
Ok can confirm that adapter seems to be the problem
will give proper test this weekend when connected to mill and report back with links to the adapters
Thanks Andrew
andrewbishop66
Re: Huanyang Plugin
Postby alex_s » Wed Nov 08, 2017 8:48 am
i got several adapters, and all with the "ch340T" chipset seem to work.
alex_s
Re: Huanyang Plugin
Postby Dan911 » Wed Nov 08, 2017 11:44 am
Gerry gives a link on his 2017 screenset site.
http://www.thecncwoodworker.com/uccnc.html
Re: Huanyang Plugin
Postby ger21 » Wed Nov 08, 2017 11:46 am
Yes, and it also uses the CH340 chipset.
Re: Huanyang Plugin
Postby andrewbishop66 » Wed Nov 08, 2017 9:41 pm
So got out to the workshop tonight and 5 mins everything up and running with no issues the adapter I had no problem with was
https://www.amazon.co.uk/gp/product/B01 ... UTF8&psc=1
WINGONEER USB-485 USB to RS485 Converter Adapter Window 7 / 8 XP Linux Vista
The one that would not work although serial data logger showed it was is this one
https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1
SODIAL(R) USB to RS485 USB-485 Converter Adapter Support Win7 XP Vista Linux
I expect that the one that didn't work properly has a counterfeit serial chip inside
Spindle now works fine on standard screen set and 2017 screen set
Thanks Andrew
andrewbishop66
Re: Huanyang Plugin
Postby Dan911 » Thu Nov 09, 2017 2:13 am
Happy it worked out for you in end. Thanks for the update!
Re: Huanyang Plugin
Postby 4.2A » Tue Dec 12, 2017 4:57 am
I'm still running an "old" UCCNC 1.2039 with plugin HY12.
Is there a new HY plugin to install with the current UCCNC 1.2047?
With kind regards - and 4.2A
4.2A
Re: Huanyang Plugin
Postby Dan911 » Tue Dec 12, 2017 6:21 am
4.2A wrote:Hi,
HY12 will work with 1.2039 and higher which includes the latest version 1.2047.
