WHB04B-4 Pendant Plugin
Re: WHB04B-4 Pendant Plugin
Postby shad » Wed Oct 28, 2020 6:31 pm
Please click on the pendand plugin icon in the lower right corner of the Windows.
Plugin window will be open for configuration.
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
http://neuroncnc.com/
shad
Postby drumsticksplinter » Thu Oct 29, 2020 2:58 am
Hi guys,
I have the older HB04 wireless pendant using the plugin for that device. I’m having some difficulties which I’m wondering if anyone else has experienced with a third party pendant? I’m using an AXBB-E motion controller and when using this the pendant controls aren’t all working and it locks up or crashes when switching between modes. However, if I switch to a demo profile of another cnc drive controller (I don’t have any other hardware available to test) my pendant works absolutely perfectly, all functions and accurately! I’m wondering if it’s a bug with the AXBB-E profile? CNCdrive aren’t forth coming with any solution as of yet despite this being offered as a function of their software at the time of purchase. I don’t want to buy another pendant at this point because I may run into the same issue if it’s actually a bug in the AXBB-E profile and it’s MPG functions.
Any advice would be appreciated, thanks.
drumsticksplinter
Postby Delco » Thu Oct 29, 2020 3:58 am
shad wrote:Please click on the pendand plugin icon in the lower right corner of the Windows.
Thanks never thought to look in the windows taskbar area , all working great :)
Delco
Postby drumsticksplinter » Thu Oct 29, 2020 11:47 am
I've just installed the latest version of UCCNC (1.2111) and my HB04 now works with the plugin included with the software, even using the AXBB-E demo, which previously it didn't under version 1.1xx.
I'm yet to try it live with my hardware attached, so hopefully it will be ok. I've waited a while for this to be possible and hadn't tried the latest software version as I hadn't had an update from cncdrive saying it had been sorted. Thanks for this fix :D
drumsticksplinter
Postby RRocadas » Mon Nov 02, 2020 12:11 pm
Hi all
In Diy cnc i have just installed this plugin and work perfect with my WHB04B-4.
The only thing i have to understand is how to djust manual jog because when starts if i chose for example x axys it moves only 0.01 unit per move then i have to click on continuos and step several times until jog correctly but that's perfect!
Very thank you for this plugin.
RRocadas
Postby Tobe91 » Fri Jan 29, 2021 4:15 pm
I just tested the WHB04B plugin, and it works well.
I just wondered if it would be possible, to set the MPG speed multiplier according to the percentage on the speed selector wheel?
So I mean: We have the speed/step selector on the right side of the pendant with 0,001 (2%), 0,01 (5%), 0,1(10%), 1,0(30%), 60%, 100% modes.
I think it would be cool, to attach the percentages to the maximum pre-selected speed multiplier or?
E.g.: I would set the speed multiplier to 100
When I select the 2% mode then the speed multiplier would be speed multiplier 2, when I select 30% it would be 30.
Another possibility would be, that we can define specific speed multipliers for the different modes of the selector wheel, e.g.
percentage -> speed multiplier
2% mode -> 5
5% mode -> 10
10% mode -> 25
30% mode -> 50
60% mode -> 100
100& mode -> 200
With this it would be possible to do fast movements for long distances with a high value and then fine accurate movements when selecting a small value.
Would this be possible? I think this would be a nice feature.
Tobe91
Postby picposter » Sun Jan 31, 2021 2:18 pm
pmorton wrote:I am new to this forum, so please excuse me if I am repeating others' questions.
I downloaded and put the .dll into the UCCNC folder but the software doesn't seem to be picking it.
I keep getting the "Receiver Not Connected" message
any help would be helpful.
I am using UCCNC 1.2049 (so it's not the latest) with UC300eth board. I was using the UCR201 but that won't connect either
it is quite possible I am doing something stupid as I am still somewhat new to the CNC world.
thanks
Paul
You have to put the .dll File in "uccnc/Plugins". In the Plugins Filder there are also the Webcam Plugin and all the Others. Then start UCCNC and go to Plugins and enable WHB04B-4 Pendant and restart UCCNC. Now Switch on the Pendant and cunfigure the plugin.
The plugin in the very First Post worked Well.
Good Luck
picposter
Postby picposter » Sun Jan 31, 2021 3:06 pm
At first: this plugin is AWESOME!
Thank you so much for the effort you put in that.
I found some misbehaviour in my setup:
I have 6 axis WHB04B and 6 axis driver from here. Using newest UCCNC with a AXBB-E.
When i am in "MPG cont" Mode and the feedrate rotary Switch is set to any value of 2%, 5%, 10% or 30% any axis will not run smoothly. It also doesnt recognize all "steps" from the handwheel.
If i change the feedrate switch to a value of 60%, 100% or Lead the axis run like a charm but very fast because the step distance is set to 1.
In 60/100/Lead position i can change the step distance without problem, also with a Macro button. But when in 2/5/10/30 position the value jumps back directly when i change the value. Like its constantly sending the corresponding "step dist." for that feedrate position.
Maybe this constantly sending brings the "smoothness" down.
greetings
Cedric
picposter
Postby Tobe91 » Mon Feb 01, 2021 10:39 am
I just found out, that the plugin isn't saving my entered Speed Multiplier values.
So when I restart UCCNC, the settings are gone.
Is there any solution, or does anybody have the same behavior?
It also looks like, if I'm entering a different value for speed mutliplier, the plugin doesn't recognize it.
Is there some solution?
Tobe91
Postby shad » Mon Feb 01, 2021 8:34 pm
Hello!
I know this issue with speed multiplier.
On the next week the pendand will be in my hands and I hope can solve this isssues.
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
Users browsing this forum: No registered users and 154 guests
