ProbeIt for UCCNC
Re: ProbeIt for UCCNC
Postby thegreatwaldo » Sat Mar 28, 2020 5:55 pm
Hi Eric
I got it to work when I logged on as Administrator. and worked perfectly however on my normal login it only worked on 100% scaling. On other scaling even with the box unticked the screen wasn't right. I've got a big 4k monitor for my normal work and i've a feeling there's some driver issues. I'll try it tomorrow on my cnc controller pc and see what happens. I did notice in demo mode on my 4k machine when I press the reset button which is blinking when I start uccnc the plugin box closes, is this normal ?
Cheers and stay safe
Andrew
thegreatwaldo
Postby thegreatwaldo » Sat Mar 28, 2020 9:23 pm
Hi Eric
Still had problems with the screen on the other computer but just set it on 100% as it's a smaller monitor so no problem. And the program screen disappearing was because I had it set on call startup. I'll try it out tomorrow.
Cheers
Andrew
thegreatwaldo
Postby sgenevay » Sun Apr 05, 2020 11:34 am
Mmmmmmmm so bad this plug in looks like exactly what I would love to use..... But even by placing all the files in correct place the plug in doesn't even appear in my plugin list in uccnc
Best
Sylvain
sgenevay
Postby eabrust » Sun Apr 05, 2020 12:11 pm
sgenevay wrote:Mmmmmmmm so bad this plug in looks like exactly what I would love to use..... But even by placing all the files in correct place the plug in doesn't even appear in my plugin list in uccnc
Best
Sylvain
Hi Sylvain,
What version of UCCNC are you using? I had someone contact me recently trying to use it with a 'Stepcraft' version of UCCNC, which isn't a problem in itself, but I think the version of UCCNC that it was based on is the issue (they had something like v 1.2006 of UCCNC, and plugins weren't showing up). It was an older version before the plugins were based on .Net 4.0, and I believe that was the issue. Once he installed a recent UCCNC version, no issues loading any plugins.
Please install one of the recent development versions of UCCNC from here: http://www.forum.cncdrive.com/viewtopic.php?f=2&t=240&p=18850#p18850. I believe the last stable release v1.2111 would also work fine. FYI, you can have a number of UCCNC versions loaded next to one another for testing purposes, and so you don't have to alter your existing setup either. I like keeping a number of versions installed (I currently keep 6 versions installed), and using version number as part of its install folder name.
Postby sgenevay » Sun Apr 05, 2020 12:37 pm
OK thx Eric ...
My version was too old... It seems to work now I will test it today !
Do u know what will be the final price I will be really interested ?
Sylvain
sgenevay
Postby sgenevay » Sun Apr 05, 2020 3:10 pm
Argh... It doesn' work on the 1.2049 (which is the last working version with 2017 screenset :-(. )
Sylvain
sgenevay
Postby ger21 » Sun Apr 05, 2020 11:00 pm
The 2017 Screenset should still work with newer versions of UCCNC, but you won't have access to any of the newer features.
Postby sgenevay » Mon Apr 06, 2020 5:44 pm
ok so yes it's working... i didn't totally finished the install that was why .... but that didn't resolve my probleme.... UCNC is crashing and just quit too often.... but that's another subjects... thx for help to you both anyway :))))
Sylvain
sgenevay
Postby ger21 » Mon Apr 06, 2020 6:09 pm
I don't think I've ever seen UCCNC crash? PC issues?
Postby sgenevay » Tue Apr 07, 2020 8:45 am
I dunno this is my work pc... not connected to internet... i'm working in Music Area with it. i have no one problem with it out of that crashing issue with uccnc... it generally happens between 2 different programs run... and this is very annoying cause when UCCNC quits it doesn't save the cnc position.... so the whole piece is crashed cause my 0 point is lost. I don't understand what causes this....
Sylvain
sgenevay
