Huanyang Plugin
Re: Huanyang Plugin
Postby Dan911 » Tue May 16, 2017 2:23 pm
If you already have VFD wired with relay turning spindle on/off I would recommend keeping that. The ModbusEZ plugin works the same as the HYplugin and also has a feature for Rpm only, this would just set your speed. IMO the plugins are much quicker in setting rpm and more accurate than using analog.
I have a manual 1/2 written for ModbusEZ plugin for a week now, if I stay not so busy at work I my complete today and post.
Re: Huanyang Plugin
Postby andrewbishop66 » Tue May 16, 2017 3:53 pm
Thanks Gerry
andrewbishop66
Re: Huanyang Plugin
Postby andrewbishop66 » Tue May 16, 2017 10:12 pm
And
thanks dan for taking the time in the first place
Im afraid im a bit late to this party am i understanding this right spindle on off controlled by relay as normal but the plugin controls the speed
at the moment mine is controlled by step and direction but as im changing the board Im looking at all options
Thanks Andrew
andrewbishop66
Re: Huanyang Plugin
Postby ger21 » Tue May 16, 2017 10:31 pm
The plugin can optionally turn the spindle on/off, so you have multiple options.
Re: Huanyang Plugin
Postby Dan911 » Wed May 17, 2017 2:35 pm
Hi Andrew,
Sorry, I missed the part where you were changing the board and my answer was based on an already working system controlling spindle. Yes, the plugin can control spindle 100% through UCCNC software without any additional wiring to your hardware like Gerry already posted. Below is a video of setup for the HYPLUGIN, the ModbusEZ plugin works and setup is the same.
https://youtu.be/z2naKHGc9jA
Re: Huanyang Plugin
Postby andrewbishop66 » Wed May 17, 2017 8:36 pm
Thanks Dan
Do you know if I can control a Watt L2000 drive although the manual shows a serial connection the isn't any info in the manual
Typical just when it was getting interesting
Thanks Andrew
andrewbishop66
Re: Huanyang Plugin
Postby ger21 » Wed May 17, 2017 10:01 pm
I just looked in the manual, and it doesn't look like it.
I see a picture pointing to a "serial interface", but no mention of any modbus or control through a serial port.
Re: Huanyang Plugin
Postby A_Camera » Thu May 18, 2017 8:45 am
andrewbishop66 wrote:Do you know if I can control a Watt L2000 drive although the manual shows a serial connection the isn't any info in the manual
Page 38 is pretty clear about it.
Frequency source:
There are three different ways to set the output frequency:
00: using the potentiometer on the digital operator
01: using analog input terminals O (0-10V) or OI (4-20mA)
02: using functions F 01 or A 20
Run command source:
The command for starting the motor can be issued via:
01: the digital inputs configured as FW or RV
02: the RUN key on the digital operator
The option for controlling via communication is missing from the settings. I guess they are using the same drawing for other models with serial interface, though I could not find any of theirs with Modbus.
Critical Update!
Postby Dan911 » Sat Jun 03, 2017 10:14 am
It's been reported that when using the Amp read feature in plugin it's possible for a new command to get stepped on and missed. I consider this a critical update for anyone using this plugin and strongly suggest to updating to the new version HY12 where it's been fixed. It can be downloaded by following link below.
HY12 will ONLY work with the newest UCCNC version 1.2038 and 1.2039.
http://www.cnczone.com/forums/uccnc-con ... ost2053768
Re: Huanyang Plugin
Postby andrewbishop66 » Sun Oct 29, 2017 10:04 am
MillGarage_Probe1.pro
(32.41 KiB) Downloaded 961 times
Hi Dan would have posted this over on cnc zone but wasn't sure how to upload a profile
would you take a look at my profile and let me know if it looks ok as I cant get the spindle to work
running 2017 screen set
I have a mill with pulleys and I normally run between 30hz and 70hz for spindle control any pointers where I'm going wrong my old spindle is controlled by step direction so I haven't changed that data so I can switch back to the old settings
the plugin picks the com port ok
Thanks Andrew
andrewbishop66
