Huanyang Plugin
Re: Huanyang Plugin
Postby Dan911 » Tue Mar 14, 2017 3:21 am
Hi QuebecCNC,
Don't bother downloading the plugin I uploaded for you I determined what your problem is. Go to your spindle set up in UCCNC (CONFIGURATION/AXIS SETUP/SPINDLE) and check "PWM spindle" you have "Step/direction spindle" checked and this is your problem. When I checked this my max rpm went to "11880". You will need to apply/save restart after changing these settings.
I will add this to the set up instructions sometime in future.
Re: Huanyang Plugin
Postby QuebecCNC » Tue Mar 14, 2017 2:18 pm
Great I will test that tonight.
Thanks!
QuebecCNC
Re: Huanyang Plugin
Postby ger21 » Sun Apr 16, 2017 4:20 pm
I just uploaded a video I did while testing Dan's plugin.
Excellent work.
https://youtu.be/jmdV3Y_ffyo
Re: Huanyang Plugin
Postby Dan911 » Sun Apr 16, 2017 7:59 pm
Thank You Gerry, it's such a pleasure getting positive feedback. Normally the only feedback I receive is when someone has a problem. I'm sure you relate to that! lol
Have a Happy Easter Sunday!
Thanks again,
Re: Huanyang Plugin
Postby Dan911 » Thu Apr 27, 2017 4:15 pm
Hello All,
I just uploaded a new version of the HYPLUGIN and it really is a difference of night and day compared to original plugin, anyone using this plugin should take a look and download. I also fixed minor bugs and added some new features.
Read and download by following link to bottom of page:
http://www.cnczone.com/forums/uccnc-con ... ost2038336
Re: Huanyang Plugin
Postby Dan911 » Thu May 11, 2017 12:20 am
Hello All,
Recently I became aware of a bug that's actually been with the plugin from the beginning. Many haven't experienced it like myself but regardless, it was there and fixed. Anyone using this plugin or decide to give it a try make sure it's "HYPLUGIN10". You can follow link below to post#267 to download.
http://www.cnczone.com/forums/uccnc-con ... in-23.html
Re: Huanyang Plugin
Postby cncdrive » Thu May 11, 2017 11:00 pm
Hi Dan,
Thank you for your extensive work with this plugin. I really appritiate it.
Re: Huanyang Plugin
Postby Dan911 » Sat May 13, 2017 12:54 pm
I am extremely happy to share and offer anyone the same option who might of been in same predicament as me. My system was built several years back and a lot of components wasn't available like they are today, at least not reasonably priced. Mach3 was my only option if I wanted to control spindle through software without doing a complete overhaul to my Electrical enclosure, and with everything working perfectly this was a tough move to make. With your UC100, software and plugin I feel like I made this overhaul and my system can compete with most. So...Thank You!!
Re: Huanyang Plugin
Postby andrewbishop66 » Tue May 16, 2017 12:30 pm
Hi All
Can I use this plugin with other drives my mill spindle inverter has rs485 input will it work or should i stick to my existing spindle control
in the middle of setting up new controller with uc300
have to Gerrys video was impressive
Thanks andrew
andrewbishop66
Re: Huanyang Plugin
Postby ger21 » Tue May 16, 2017 1:54 pm
It only works with Huanyang VFD's.
Dan has another Modbus plugin at CNC Zone that works with other VFD makes.
