Huanyang Plugin
Re: Huanyang Plugin
Postby Archy » Sat Aug 28, 2021 11:08 pm
Sorry to necro the thread but couldn't find the info.
What is the state of this plugin, Can I get a current reading from this vfd? I want the spindle RPM if possible, current (Want to see the load on the spindle to see if the cutter is working hard), control RPM of spindle.
https://www.iot-store.com.au/products/d ... -usr-dr302 - I want to use this for the rs485
https://www.makerstore.com.au/product/elec-vfd-2200/ This is the VFD I am looking at getting. I cannot find the Hitachi VFD in Australia. Will this work with the rs485 plugin?
Archy
Re: Huanyang Plugin
Postby ger21 » Sun Aug 29, 2021 6:58 pm
The author stopped posting a few years ago, and the plugin hasn't been updated since then.
Can't tell if that adapter will work. If Windows sees it as an RS-485 port, then it should.
If that VFD is a genuine Huanyang, then it should work with this plugin.
Re: Huanyang Plugin
Postby naijin » Mon Apr 17, 2023 10:48 am
Hi there, this plug in, will it work with the AXBB-E controller? do I need a plug in with the AXBB-E or just set it up?
Cheers
Nick :roll:
naijin
Re: Huanyang Plugin
Postby ger21 » Mon Apr 17, 2023 11:06 am
the plugin will work with any controller, as it doesn't use the controller.
Re: Huanyang Plugin
Postby naijin » Mon Apr 17, 2023 1:22 pm
O.K, thanks Ger21 for the quick reply, I just found the spindle set up in UCCNC and I will give it a try. :D
Cheers
Nick
naijin
