XBox 360 plugin update
Re: XBox 360 plugin update
Postby neptunier » Tue Feb 18, 2020 3:21 pm
hello eric,
i wanted to use your plugin, however it does not show up in the configure plugin screen in uccnc.
i tried it on 2 computers, both are running windows 7 64bit with uccnc 1.2111. i put the xbox.dll and xbox.xml in the uccnc/plugin folder and the x64 slimdx.dll in the uccnc folder.
i also tried installing the slimdx.msi on both computers, no luck.
is anybody else having these issues or can someone help dissolve the issue?
thanks,
michael
neptunier
Postby eabrust » Tue Feb 18, 2020 4:42 pm
Hi Michael,
when you say you tried to install the slimdx.msi, do you mean you installed the SlimDX SDK: http://www.craftycnc.com/download/585/
If you haven't, please try restarting your PC since installing the SDK. Let me know how that works out and we'll go from there.
Postby andreiir » Tue Mar 10, 2020 12:30 am
Ur plugin seems to work ok , but i was wondering if u we can assign lower buttons on xbox joistick some commands , i didnt find this , i want to put feedrate on left part with lower button go down , and upper button ls go up feedrate , and for the right side for joging feedrate .
Thanks.
andreiir
Postby eabrust » Tue Mar 10, 2020 12:44 am
andreiir wrote:Ur plugin seems to work ok , but i was wondering if u we can assign lower buttons on xbox joistick some commands , i didnt find this , i want to put feedrate on left part with lower button go down , and upper button ls go up feedrate , and for the right side for joging feedrate .
Thanks.
Hi andreiir,
I assume you are referring to the cross-shaped DPad buttons, correct? I'll make note to look at making those programmable for a future revision.
Postby eabrust » Tue Mar 10, 2020 3:04 am
Whoops, I actually forgot I already made the dpad and shoulders programmable as an option.
You need to check the 'customize dpad/shoulder' checkbox, then enter in the code numbers for the events you want to happen (hint, use the 'show button code help file' to pull up the list)
can't remember what I've forgotten some days.... :oops:
Postby sgenevay » Thu Apr 09, 2020 11:23 am
Hello Eric.... continuing here as u said.... the xbox plugin simply doesn't work to me.... the statut bar shows a "loop fault" message... i have try to install the additional file u gave but with no success... the plugin doesn't react neither the wired controller nor the wireless... no reaction from the plug in or from uccnc with or without enable joging checked...
Sylvain
sgenevay
Postby eabrust » Thu Apr 09, 2020 1:07 pm
Hi Sylvain,
Did you install the slimDX SDK from here (copy pasting from an earlier post):
I must now (again) recommend if you are installing the XBox Plugin for the first time, install the SlimDX SDK too....
Link to SlimDX 2012 SDK: http://www.craftycnc.com/download/585/
and reboot after?
It sounds like you're at that point where everything is installed, except for the background directX stuff that the above link provides.
Postby sgenevay » Thu Apr 09, 2020 1:22 pm
thx for your answer..... at first i installed it with the link provided under the xbox plugin link in your site, as i saw u recommanded to install it... then i saw this forum and i have installed the one i saw, and finally so i took the one u just gave me (even if i assume this is the same as this is the same link)... uninstalled, reinstalled it and reboot... and it's the same with same "loop fault" message...
also something, when i click to uncheck the "enable joging" case, i have an error message: "unhandled exception has occurred in your application. if u click continue, the application will ignore this error and attempt to continue.if u click quit, the application will quit immediately"
Sylvain
sgenevay
Postby eabrust » Thu Apr 09, 2020 1:27 pm
Does your controller show up as an installed 'xbox' controller under windows hardware list? (not as a generic control or gamepad, but does it look like an xbox control?)
Yes, if the plugin shows a fault that it can't connect to the controller, trying to enable it further will cause problems. :)
Postby sgenevay » Thu Apr 09, 2020 1:32 pm
the 3 are recognised as:
- Xbox360 controller for windows
-Xbox360 Wireless receiver for windows
-Xbox 360 Wireless controller
and btw they are effective in windows to move selections...
i have try it with one connected... then the other... then the 2 of them ...
Sylvain
sgenevay
