Autoleveler Plugin.
Re: Autoleveler Plugin.
Postby lazy_23 » Tue Sep 03, 2024 8:53 pm
Hi to all.
I am not an expert and I spent two days trying to use the Autoleveler Plugin (AP), here is my setup:
Controller AXBB-E, UCCNC v1.2113, AP v 2.0049.
I use an inexpensive Touch Plate Tool as zero probe that is a cilinder hight 19.3mm (tool z offset).
My workflow: load in AP the toolspath g-code generated by Cut2D (post processor UCCNC(mm), the gcode seems ok), setting the AP as in picture
but the gcode sent to UCCNC have a huge z value in the cutting profile: after gatering all probe points, when the CNC begin to cut, the endmill go down to 193mm instead of about 30mm from the travel altitude [attachment=2Screenshot 2024-09-03 221959.png[/attachment].
I hope I was clear...
My question is: do I typed the right parameter in the Autoleveler Plugin (shown in picture)?
Would I use a newer version of the AP? (I tried AP v 3.031 but the tool z offset is missing)
Thank you in advance for any help
lazy_23
Postby soliman » Mon Sep 16, 2024 5:37 pm
cahit wrote:hi,
i want to try to add import gerber option to autoleveler. That's why I need help to get as many examples as possible to compare files. please help me send several so that I can study them. of course different generators.
thanks in advance.
cahit ates
c.ates@hotmail.com
Hello
I would like to know how setting for made PCB using UCCNC
soliman
Postby soliman » Mon Sep 16, 2024 5:42 pm
Hello,
Would like to know how setting to work which PCB using UCCNC 1.2113 version any help please.
AutoLevelerCA 1.0048
soliman
