XBox 360 plugin update
Re: XBox 360 plugin update
Postby eabrust » Wed Feb 08, 2017 3:55 am
spumco wrote:Eric,
Finally got a chance to install the latest version - MAGIC.
Motion on the Z is superb. Very smooth and I can creep a 'thou at a time with no jumping. The trigger safeties are awesome, especially for clumsy me.
Having the keyboard jog enabled would be nice, but now that the controller is so sweet it seems a bit superfluous.
Thanks again so much for your work.
Regards,
Spumco
Thanks for the feedback, and catching my error on the right stick :)
I intend to correct the jog button 'lock out', I know what is wrong, just no time to work on it.
Eric Brust
Postby sgenevay » Sat May 20, 2017 12:08 am
impossible to install slimdx here.... :( :( :(
sgenevay
Postby epracefan@gmail.com » Tue May 30, 2017 12:26 pm
Has anyone used this with a wireless controller? I don't currently have any game controllers so want to make sure I buy one that works well.
Thanks for writing this plugin, I'll be testing it soon.
Ed
epracefan@gmail.com
Postby eabrust » Wed May 31, 2017 3:09 am
Hi Ed,
I can only confirm that I've tested with a wired xbox controller . I'd presume it will work with an actual MS wireless xbox controller, but I can't guarantee it.
Postby epracefan@gmail.com » Thu Jun 01, 2017 2:31 pm
Thanks Eric. As soon as I can get to it, I'll give it a try and post my results.
Ed
epracefan@gmail.com
Postby epracefan@gmail.com » Sat Jun 03, 2017 1:36 am
I gave up trying to find the wireless XB360 with receiver. I know they can be purchased on eBay, but was hoping to find something local. Ended up getting a wired clone from Walmart for $19.77, make is PowerA. Seems to work as expected although I haven't spent much time with it yet. I'm running UCCNC on a Windows XP box and drivers for the controller downloaded automatically when it was plugged in.
Thanks Eric, for taking the time to create this plugin!
Ed
epracefan@gmail.com
Postby epracefan@gmail.com » Tue Jun 06, 2017 1:44 am
Just a quick update on my experience with the XBox 360 plugin. Everything has worked as expected and motion is smooth and easily controlled. The only issue I have come across is with programming a button to execute the park macros. The screen buttons work as expected, but the programmed XBox buttons do not. I suspect the problem is related to my use of the 2017 screenset and not with the plugin. Gerry probably wrote his own macros for that as he provides for setting the park locations from within the program. Other than that one problem, the plugin works great!
Thanks again,
Ed
epracefan@gmail.com
Postby Battwell » Fri Jul 21, 2017 4:04 pm
i tried a while ago and my pc wouldnt allow me to download slimdx - saying it wasnt safe!
ive just downloaded it - and your updated plugin today- so will now install and give it a whirl!
analogue joysticks- cant wait !!!
Postby Battwell » Sat Jul 22, 2017 6:09 pm
anyone else had trouble with slimdx install?
it installs great on my office pc. but (exact same pc) running my machine it gets most of the way then fails. says it cant run a program. then rolls back to uninstall
re downloaded etc.
im taking it to my machine pc on usb stick (tried 2)
Postby cncdrive » Sat Jul 22, 2017 10:05 pm
It's possible that I'm wrong, but I think you have to install DirectX for SlimDX to work.
MAybe the issue is that the required DirectX version is not installed or is broken.
I would try to reinstall DirectX to see if it resolves the issue.
