UC.Stop() not stopping all axis moving if macro is running
Postby AutomaticInvest_4 » Tue Nov 19, 2024 11:34 am
Hello
I have a plugin where I call UC.Stop(); to stop axis moving, but if a macro M3xx is running then only the current G01 running inside the M3xx macro is stopped..
So if the macro is something like
G01 ..
G01 ..
G01 ..
and the UC.Stop() is called while the second G01 is running inside the macro then it is stopped but the machine continues to execute the third G01
AutomaticInvest_4
Re: UC.Stop() not stopping all axis moving if macro is runni
Postby cncdrive » Tue Nov 19, 2024 9:05 pm
You can check the exec.Ismacrostopped variable before executing motion commands to skip those commands or any other commands if the Stop() function was called meanwhile executing the macro code.
Postby AutomaticInvest_4 » Thu Jan 16, 2025 1:50 pm
Yes maybe you are right, but for the moment I just write
while exec.IsMoving()
UC.Stop();
so that I stop all movements in case a macro is running
AutomaticInvest_4
Users browsing this forum: No registered users and 22 guests
