plugin defective message
Postby MrBean » Sat Sep 14, 2024 10:42 am
I try to run the AXBB-E on a new Windows 10/64 with Mach3.
When starting Mach3, I get the "plugin defective" message.
The plugin was installed plugin with the UCx00 plugin installer.
The .net framework 4.8 in Windows is enabled.
What else can I try?
MrBean
Re: plugin defective message
Postby cncdrive » Sat Sep 14, 2024 3:39 pm
Enable the .net framework 3.5 in the Windows features and reboot Windows.
.net 4.8 is not backwards compatible with the .net framework 3.5.
.net framework 4.8 is not backwards compatible with the .net framework 3.5.
