setting a distance to move in the jogging window
Postby thegreatwaldo » Tue Mar 14, 2017 11:38 am
Hi would it be possible to have a tab in the jogging window to move a specific inputted distance (winpcnc has this feature)? say for example move router 10 cm in x + dirrection. This would be triggered by a button and not an external mpg controller.
Cheers
Andrew
thegreatwaldo
Re: setting a distance to move in the jogging window
Postby ger21 » Tue Mar 14, 2017 12:01 pm
Just set jogging to step mode, enter "100" in the step increment DRO (100mm = 10cm), and click the jog button.
Postby thegreatwaldo » Tue Mar 14, 2017 12:09 pm
ger21 wrote:Just set jogging to step mode, enter "100" in the step increment DRO (100mm = 10cm), and click the jog button.
Thanks Ger
I'll try that when I get home this evening.
Cheers
Andrew
thegreatwaldo
Postby A_Camera » Tue Mar 14, 2017 2:18 pm
Thanks Ger
Cheers
Andrew
Be careful with that... if you are not alert you can easily forget and smash into something. But of course, if that's what you want it is easy. Personally I'd be scared to do that, especially with such large distances.
Postby thegreatwaldo » Tue Mar 14, 2017 11:20 pm
Hi Ger
I tried to set the step distance to 100 but it jumped back to the step distance setting in the dro above the step button also moves very slowly. Am I setting the correct box. using ver 1,2033 Using a x-box controller movement is fast per normal. Any help gratefully accepted. Using a UC100.
Cheers
Andrew
thegreatwaldo
Postby ger21 » Tue Mar 14, 2017 11:28 pm
I see that the DRO is limited to a max of 10. You can change it to allow higher numbers with the screen editor.
I believe that the step jog moves at the feedrate in the Fset DRO.
Postby thegreatwaldo » Wed Mar 15, 2017 12:32 am
ger21 wrote:I see that the DRO is limited to a max of 10. You can change it to allow higher numbers with the screen editor.
Hi Ger
Thank you. I'll check that out tomorrow and see how it works out.
Cheers
Andrew
thegreatwaldo
Postby thegreatwaldo » Wed Mar 15, 2017 8:02 pm
Hi Ger
I managed to change the DRO but the feed rate is still very low and the Fset button doesn't seem to be adjustable by clicking on it. it's just set on 6. The sytem in winpcnc usb has a move jog box with fields where the user just inputs a distance (units are selectable as well as direction) I just need this kind of setting to cut simple slots or box cutouts on the fly. Any ideas ?
Cheers
Andrew
thegreatwaldo
Postby dezsoe » Wed Mar 15, 2017 9:23 pm
You have to set the speed with the F word for the step jogging instead of the current JRO or Shift key.
(It's a new feature, but I personally really hate it. :( As old CNC users say, it is in the same way on factory CNCs.)
Postby thegreatwaldo » Wed Mar 15, 2017 11:02 pm
Vmax549 wrote:Testing here teh Window can be set to any step distance and each click moves that distance using teh Fword Speed OR you can hold down teh SHIFT key and click and it moves at rapid rate.
Pretty much as GOOD as it gets ;)
V2033
(;-) TP
Hi Vmax
I'll give that a try tomorrow, it's been a long day. Thank you.
Cheers
Andrew
thegreatwaldo
