Zoom to the mouse pointer in toolpath
Would it be possible to make it so when you zoom in using the mouse wheel in both/either the run/toolpath tabs where it visually shows the gcode it zooms to where the mouse pointer is instead of the current center of the screen?
As a second request how hard would it be to implement a feature where you can, under the toolpath tab because its bigger, be able to make a button where you are in a top view and then you click a goto this point button then click on the display area? Like this:
1. User selects toolpath tab
2. User selects the top view
3. User selects a button that say "Jog to a point"
4. User clicks on a space in the toolpath display area
5. Machine jogs to where the user clicked.
This would be helpful for locating clamps on complex setups and for finding where to put screws when your screwing down a 4x8 sheet with multiple parts on it.
Great software and am strongly considering replacing/augmenting Mach3
