here is my feature request.
Simple Undo function/button.
There are many actions that can be logically undone and the operator will benefit from if he/she can undo them.
Scenario:
Say we do a step x, y, z, .. who knows what.. and at some point instead of pressing "home" you press "Zero Axis" which is close to Home button on UCR201 .. and the setup is ruined and it need to be done again.. which is not always one easy process. if there is be undo such mistake will be no problem at all..
List of applicable undo:
- set zero for any axis
- set a value for any field, like speed, coordinates, go to relative and absolute
- feed set
- set actual line
- reset buttons [time reset, log]
- reset angle
- reload file
- etc.
indeed there are many things where undo would not make sense, but there are many where it does.
Coz we make mistakes and forget previous values in an instant.
The undo would save as a ton of machine repositioning and more.
When the Undo is pressed the action will be seen in in the log, in both cases when it was applicable in that case what has been applied, and if it is not possible the log would mention it too.
