intial feed rate
intial feed rate
Postby jsim8909 » Thu Mar 28, 2019 4:38 pm
I would like to know how to setup initial feed rate at startup to lower value than 100%. Say 20% on opening. I sometimes miss lowering it when performing moves that should be lower. I would rather be inconvenienced with raising it after the fact than having damage happen because I forgot to first lower it. in other words safe startup rate I later raise when needed.
Life is what happens when your busy making other plans!
jsim8909
