UCR201 button fonction...
Postby cahit » Sat Nov 17, 2018 8:32 am
Hi Balazs,
I am a very hapy user of the UCR201.
is it posibile in the plugin if push twice the "Zero Axis" button that zero's all the axis's x,y,z,a,b,c?
like if you press twice the stop button. second time it rewind a file.
now i have to chance the axis for every axis and press "zero axis" button for every zero it.
cheers
cahit
cahit
Re: UCR201 button fonction...
Postby cncdrive » Sat Nov 17, 2018 10:14 pm
Hi Cahit,
I'm happy to hear that you like the UCR201. :)
Well, I'm not a fan of the double button presses idea, because you know then shaking hands can lead to issues, I mean if the machinist pushes the button twice without realising that he did it and then the axes zeroed or the file rewinded ... this could easily cause serious issues.
What about programming the 5 function buttons to do these things for you?
Postby cahit » Tue Nov 20, 2018 4:07 am
hi Balazs,
You are right, I have not thought about that. but long press, is that not an option to zero all axises?
of course I can also use one of the F buttons. but I want to use as little as possible. because there are only 5 pcs.
have a good day
cahit
