3D Probe deflection calibration using ring gauge
Postby eddyheide » Sat Jan 18, 2020 11:33 am
HI,
Is there a way to calibrate the deflection of a 3D probe, by using a ring gauge or something like that?
I converted a Renishaw CMM probe for using on the CNC machine, but it has (a very little) deflection when probing.
I would like to have a way to compensate for it.
Something like this https://youtu.be/MDrLA4ID_wM?t=559 (this is for eding CNC)
Maybe the feature is already here, but I can't find it. :-D
thanks in advance guys!
also, thanx Dezsoe for Fixing the drilling issue I had last year, its working great now!
Greetz, Eddy van der Heide (the Netherlands)
eddyheide
Re: 3D Probe deflection calibration using ring gauge
Postby Delco » Sat Jan 18, 2020 10:55 pm
Would you not just set the probe dia offset by that amount , ie if your probe tips measures 3mm and there is a 0.15mm deflection or pretravel before trigger then your actual effective probe dia is 3mm + 0.15mm +0.15mm ( pretravel = and - ) so a total of 3.30mm probe dia.
Delco
Postby eddyheide » Thu Jan 23, 2020 12:22 pm
Hi Thanx for you answer,
I Wish it where that simple.
Do you know how I can measure the deflection? I don't know the exact value.
That's why I would like to have a calibration procedure.
I have a couple of ring gauges, and saw the procedure Eding has, I think it add's a lot of value and precision to the 3D probing process in UCCNC
Thanx
eddyheide
Postby dezsoe » Thu Jan 23, 2020 12:29 pm
Hi Eddy,
I'll try to find out something, but it will take some time. I keep this thread open to remember. :)
Postby Vmax549 » Thu Jan 23, 2020 3:40 pm
It is that simple (;-). Take a known diam ring guage. Probe for inside diameter. Known Diam - Probed diameter gives you the probe tip diam accounting for all offset variables. If you need teh probe tip offset (tip radius) then divide by 2.
Just a thought (;-) TP
Vmax549
Postby Delco » Thu Jan 23, 2020 10:33 pm
you can also put a indicator on the probe tip and actually measure the deflection when it triggers , no different from calculating effective probe tip from a known dia ring using the software ( assuming your steps/unit is accurate - if not then the software method is a more accurate approach.
This is a interesting video on pretravel
https://www.youtube.com/watch?v=Qtg6K27h_eI
Delco
Postby Vmax549 » Fri Jan 24, 2020 12:17 am
I don't recall any process more accurate or simpler than teh Ring Guage method.
(;-) TP
Vmax549
Postby xillianto » Tue Oct 13, 2020 6:02 pm
Would love for the calibration to be entered aswell into uccnc development.
But is there anyone who could make a macro for this perhaps ? To measure travel between 2 contact points perhaps ? Atleast we get a number that we can enter manually to correct the probe tip diameter
xillianto
Postby dezsoe » Tue Oct 13, 2020 7:42 pm
Have you seen the probe screen?
