Launch arguments
Launch arguments
Postby Fabien » Fri Jun 21, 2019 8:07 am
I have multiple instances of UCCNC running on the same computer.
/s argument is useful to select the dongle
is that possible to add:
an argument to select a jog UCR201
an argument to change the main window title (very useful if you have multiple Windows to says its's machine 1, …)
Fabien
Re: Launch arguments
Postby dezsoe » Fri Jun 21, 2019 11:09 am
You can use the attached macro as a macroloop. Modify it as you need. :)
You cannot turn a plugin on/off after the program has started.
M25010.txt
(1020 Bytes) Downloaded 779 times
Postby Fabien » Sat Jun 22, 2019 3:14 pm
Thank you for your help. I will try that.
Fabien
Postby Fabien » Sat Jun 29, 2019 5:02 pm
I wanted to integrate with a plugin but it cannot access mainform title...
Fabien
Postby Dan911 » Thu Jul 25, 2019 1:13 am
Fabien wrote:I wanted to integrate with a plugin but it cannot access mainform title...
You can access the mainform title with System.Windows.Forms ContainerControl by using the Text override.
 public Form(UCCNCplugin Pluginmain)
            InitializeComponent();
            this.UC = Pluginmain.UC;
            this.Pluginmain = Pluginmain;
            Text = "Put your string here";
Postby Fabien » Mon Feb 22, 2021 8:02 pm
Thank you for your help Dan911 (sorry for the very late response).
Fabien
